Replacement for 997 PCM Head Unit
- Thread starter reevers
Colgy
If you don't have the Bose amp, then a headunit should be straightforward, if that's the route you want to go.
I did all the work myself, but not for the faint hearted. I had Bose in my car so had to replace the amp and removed the CD stacker (the new amp sits where the CD stacker was). I cut no wires and made no alterations to the bodywork so it is totally reversible.
Happy to provide more info
John H
The dash display lost the basic data it used to show replaced with -----
I had cruise retrofitted and when it was recoded by the OPC they turned off the dashes in the dash display
I put all the wiring into a new loom. Will provide pictures. Even managed to get a male/female connector that mimicked the Bose amp connection so I could plug straight into the speaker wiring.
IMO it doesn't look after market at all. Even has a Porsche logo when the unit powers up
