Hi,
Wonder if anyone can through some light on what I am being told by a Porsche garage.
I have recently fitted Eibach spring and Bilstein Sport dampers supplied from a well respected source. The springs lower the car by 30mm. As a result I was aware that ride height , toe, camber and caster would need adjusting.
The garage stated "all 4 dampers heights set the same on the bench. When fitted to the car the heights are all miles out and uneven. Removal of wheels 7 times is required to correct ride height to equal settings. Now 4 wheel alignemnt and suspension setup is carried out. The spring plate lower support heights are all set to different settings which indicate possible different spring pressure. It may transpire that the vehicle will settle and further setup may be required".
Could they have mixed front and rear springs up. I assume there would be a difference between front and rear - am I correct or wrong?
This I find most odd and I wonder if such a response is reasonable or correct? Any thoughts greatly appreciated ASAP.
many thanks
James
many thanks
James
