Replacing a wing, do you need to remove the bumper?
- Thread starter 944Scott
PSH
944Scott said:Cheers Pete that gives me enough confidence to give it a go although I believe there will be a lot of sealant holding it on.
Yes....I wasn't totally happy with the repair to my wing which means it needs to come off again, during the conversation the guy did say it shouldn't take long to remove the wing again but does involve some heat to soften the sealer...alas that's about as much as I know on what's involved, having not needed to remove the wing myself in the past......perhaps someone else here who has done this for themselves can assist more?
Pete
chrisg
1. yes there is a lot of sealant glueing the wing on
2. The 3 x 10mm bolts holding it on to the A pillar are B****ds to get out...
3. You dont need to remove the front bumper, just the bolts holding the wing to the bumper
Good Luck !
Chris
Monkeythree
The factory underseal is thick and tough. You will need a sharp chisel and lots of patience to reveal the heads of the 3 bolts which hold the back edge of the wing onto the A pillar. There is one behind the ABS pump which necessitates the removal of the plastic pump crud shield first to get to it.
Some of the fasteners at the front are into captive nuts which in fairly flimsy bits of metal. If the bolts are seized in the captive nuts then it is fairly easy to start distorting things if you try to force them. Better to cut heads off with the dremel.
Once all the bolts are out you will find the wing is still fixed firmly in place by the factory sealant and underseal. I used a pair of chisels and carefully worked them alternately to split the wing from the inner wing.
Use stainless steel fasteners when you put it back together again.
u63af
