Replacing Brake lines with Goodridge
- Thread starter silver7
The answer is...with great caution! Yes, by all means do it, but be careful to soak the unions for 24hrs with PlusGas (or WD40 which is not quite as good in my experience) first. Make sue that you use a proper brake spanner - if you strip the nuts you will have no end of trouble. Also, when you come to release the unions, give them a sharp hard tap, because the spanner will be more likely to chew the union up if you just slowly try to turn it (all brake unions are best un-done like this, must be something about the brass/copper fittings). I rebuilt my brakes all round in the autumn & although have the same hoses as you, stopped short of changing them until they really need it, because it seemed a bit of a job if you do damage the unions. Might change them sooner if anyone has done this with no problems.
Hope this helps []
Roddy
Roddy
sawood12
silver7
