My Box only does a few thousand miles a year and had a full set of disks replaced 2 years ago by the previos owner it since had done 5k miles and the disks are rotten on the rear face. is the OEM disk the best or are tehre thers that will stan up to not being used without rotting away. many thanks
replacing disks. on low use cars any alternative as mine are rotten
- Thread starter RonnieG
Jonathan G
Also remember to take the car for a drive for 10 or 15 mins after washing. This will get some heat into the disks, otherwise they will stay wet and rust! Would also suggest driving the car at least twice per week, rather than just at weekends as rust can set in when not in use. I drive my 2002 3.2S to work once per week as well as use at weekends.
Good luck with the disks.
ORIGINAL: Jonathan G
This is by far the best prevention, we also have a 2004 S, with 50,000 miles on it's original discs and pads with no signs of corrosion. I have always driven the car post washing to thoroughly dry out the discs before the car sits in the garage.
As above, drive after washing. I've got over 70K miles on mine (10 years and several trackdays too!)
If you do need to "lay the car up" for an extended time then some Carcoon CSP sprayed on will stop any rot setting in.
http://www.carcoon.co.uk/service.html
ORIGINAL: RonnieG
have you a link?? minw is a 2000 3.2S and have not found new ones that cheaap.. many thanks
design911.com - brake parts for your car
eurocarparts.com - brakes (you can do a search for your car)
porsch-apart.co.uk - brakes for your car
If you're a PCGB member you may also get a 10% discount from your local OPC - you just need to ask. Actually OPC prices for parts are sometimes quite competitive.
If they are only rusting on the rear face, it sounds like there could be a problem with the calipers, stuck piston etc as with fixed calipers there should be even pressure on both side of the disc.
yea was thinking that and an going to put a piston kit and powdercoat them over the winter. .dodgy brembo's lol.... manythanks guys. will do a bit of looking about this week shes being stripped to a shell over teh winter so will be getting a hefty shopping list... Problem is I sorn her over the winter for 6 months as I have a winter car and this is where I think the problems are arising.
They normally rust on the inside as the water seems to collect there easier. If the car is not garaged the outer faces seem to get cleared ok by any wind that is about, but the inners do not get cleared so they rust. Almost invariably the inners look far worse then the outers.
Another reason to take it for a drive after washing it.
gonzosquidgy
Bought mine from parts shop in Wakefield for £100
Link on ebay =
http://www.ebay.co.uk/itm/FRONT-GROOVED-KINETIX-BRAKE-DISCS-PORSCHE-BOXSTER-2-5-986-96-99-/250901937252?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a6aebbc64
So far, very satisfied
John
Link on ebay =
John
