Having read the wobbly mirror FAQ I thought this was going to be a 10 minute job, 3 hours later I'm still baffled.
Anyone done this (and found the screw I can't find)?
The FAQ says there is a "small screw" inside the mirror accessed from the underside.
I found 2 holes and one screw (C in picture below) (I resorted to removing mirror from door to get a better view)
Hole B has nothing inside (putting screw driver deep inside I can feel the various wires )
In hole A I can see the bottom of the mirror, or, if the mirror is tipped to the up position, I can see/feel past the notches marked in the picture below to some soft material - perhaps some foam, perhaps a cable.
pic of rear of new mirror glass from underside
Any clues please? How deep is the screw inside the case?
I've tried removing screw C and it does not release the internal mechanism - think it just secures the plastic that protects the interface between the two parts of the mirror unit.
I can't see any other (useful) screws on the PET.
Thanks for any ideas....
