Replacing front shocks on 996 C4S
- Thread starter mikegts
Pieman7
I have yet to replace mine (yet) so have no immediate experience on a 996. But any youtube video on MacPherson strut removal should give you the general idea. Safety is the main concern as the spring will be stressed even when jacked up, so spring compressors (these can be hired or bought) are a must and ensure they do not slip - injury or damage to the car could result. Without inspecting the 996 strut, you may need a deep socket (or special strut wrench) to undo the top nut, if you want to remove the spring completely from the assembly. It is a fairly straightforward job with the right tools, but suspension components in general are usually big nuts and high torque settings (with some corrosion thrown in the mix).
May need to do the top mounts and bearings on the front of my 996tt.
Will the strut come out without removing the driveshaft from the hub if the correct components are unfastened, as looking at the service manual the hub nut is done up to 450NM..or some similar silly torque. I'm used to my 205Gti which requires drive shaft removal before the hub will lower enough to remove the strut.
Also i note that the forums are arranged by model, so perhaps someone in the 997 forum may also know!
J
