Replacing PCM/SatNav
- Thread starter gaxor
If PCM1 uses a Becker CD system, then it may be worth enquiring to see if Becker can provide updated CDs. Becker. of course, do the 'Traffic-pro hi speed' system.
PCM2 cannot be retro-fitted to a pre-2003 car as it uses optical connections.
The other option is Smart Nav. This has no visible hardware. Do a search for more info.
They have an "in-car manufacturer" forum. There is a huge user base there - someone will probably be able to help.
They still supply the update disk but the most current version in 2001-2002 (at least 2 years old!) and they are in stock at around £250.
I do begrudge paying so much for something that will enevitably be wrong and out of date at times....
The disks were originally supplied by Navtech I believe but all they do now is supply the data for Porsche to package and sell......
Becker supplied radios under a Porsche badge but not a SatNav version that I am aware of. I have just sold my 964 and still have the Becker 4720 with a brand new 2004 disk that may be available if anyone is interested, my 996 has a PCM 1 in it and the becker update disks DO NOT work in the PCM unit.
An OPC said I should contact reading who may be aware of a newer disk be launched.
The disk I have for the PCM 1 is 1999 so I am looking for something newer (copy/new/used etc.)...
Just spoken to Porsche and the latest disk is 2001-2002 and nothing newer for PCM 1 or 2. He said I should contact NavTech but I have told them they they dont supply them any more.
They are going to look into it and get back to me.
ORIGINAL: beershark
There certainly was a SINGLE DIN SLOT Satnav Becker-made but Porsche-Badged one.
Not the PCM1 - just a straight upgrade unit over the normal CDR-22 radio/cd.
Does anyone know if this uses tha same discs?
You can see the Becker units here - maybe they can advise on the availability of upgrade discs?
However, if one wanted to change to an aftermarket kit - Full SatNav with CD/DVD & TV with coulour screen that replaces the 2xDin PCM module can be fitted. Porsche supply a facia panel to fit a 6.5" LCD screen !! Total cost approx £2500
