replacing seals on Targa Roof
KatharineGreen
have been quoted astronomic fee for replacing Targa front seal (3 hours labour) but helpful (and handy) hubby reckons replacing seal is easy. should I let him do it? If so, should I buy an aftermarket part (much cheaper than Porsche brand)?
many thanks
Can't be much help, as I have an after market front seal waiting to be fitted (by me)! Let me know how it goes.
One thing I can add is that I had the rear one done when having the targa hoop resprayed, and the guy (who is very experienced with older 911's) doing it said that he always has trouble with non Porsche ones as they never fit quite as well.
My motto is buy cheap buy twice!!!
I would defo buy genuine or oem parts.Things just don't fit right if they are not genuine in my opinion.
If it does not seal correctly firstly it will leak on your leather seats and secondly wind noise will be terrible.
You might be lucky but from past experiance I would personally stay clear.
Tim
What age is the Targa? I'm an ex Porsche technician and have fitted a few Targa seal, running gear ECT and trust me there's nothing easy about the Targa roofs. My advice would be getting a qualified technician to fit the seal because if it leaks or they have trouble fitting it then its there problem to sort out also all ways get the genuine seal so it fits properly.
Genuine seals every time - I bought some from Forestfine for my old 944T and ended up buying the correct OEM ones, at not much more money btw, which fitted far better too.
My car is currently in at Southbound having the targa redone and resealed. Funnily enough I had a call today advising me I need the front bar seal replacing (my bill is creeping steadily up lol), I'd give them a call if you hadn't already, the quote was pretty reasonable!
This is hubby - decided to do it myself, took 2 hours to do front seal and I am now planning to do the back seal, very simple job, 10 seconds to pull out the old seal (it was perished and came out in several chunks), approx 1 hour to get off as much of the old sealant as practical (used washing up liquid, and SOFT sponge on lolly pop stick), then about 15 to 20 mins to fit new seal. We had lots of heavy rain a few days later - NO LEAKS. Biggest problem was getting the right sealant, the most recommended product was RTV silicon, the most recommended brand was a 3m product not sold in the UK, after research on the internet I decided to use Loctite superflex (Black). Halfords show it on their website but it is a non stock item that they would order at £4.00 per 40ml tube (I estimated I would need 100ml) due to delivery costs and times I ordered the minimum qty of 12 from BRAMMER in Stratford cost £52.90 including delivery and it turned up 5 days later. I used 3 tubes (120ml) mainly due to not being able to get the last 10ml out of a tube with any precision. I have worked in IT for 25 years but was once an electrician. A mechanic that knew me as an IT person once quoted £400 to fix the air con on my car, I decided to do it myself - it was a fuse - cost 30p. I no longer listen to "It's a specialist job", "It will cost ya" and "Don't try this at home". If your thinking of replacing your seals and want some advice I'd be happy to help
