Replacing twin tailpipes on 2016 718S
- Thread starter bildar01
Theres a few options - careful that you don't pick one that only fits an aftermarket one though.
Genuine one is about £100 cheaper than the price you quoted, though you will have to fit it yourself.
I bought one for my old 987, if it is only a single pipe connection with the twin pipes coming off it, it will be easy to fit.
If its a T-shaped fitting, then you'll have to spread the silencers apart slightly so you can get the original T section of pipe out first.
A matter of slackening off one of the rear silencer hangers.
Thanks - I’ll have a look at how easy it is to get to the bolts.They should be pretty straight forward to remove by undoing a couple of bolts.
Thanks for the supplier info, what to look out for & the adviceHave a look on Design911.co.uk
