Tom
Can anyone advise on how to remove the 944 S2 washer bottle or replace the washer pump in situ?
- On my S2, the pump is way down at the bottom of the washer bottle, under the driver's side headlamp.
- The only manuals and pictures that I can find refer to earlier models where the pump is easily accessible, and mounted above the water bottle.
- I can just get to the wiring harness on the top of the pump with the headlights popped up. It feels as though the pump might just pull out of the bottle but I'm not sure. I can't see or feel any hose attached to the pump either.
- I've tried removing two bolts at the top of the washer bottle hoping that I could lift the whole assembly out but something seems to be holding it lower down. Are there more bolts lower down?
- It also looks as though I'd have to remove the chin from under the bumper to access the underside of the wahsre bottle - is this the case?
