Reprogramming keys?
- Thread starter liam996
liam996
Porsche Silverstone are going to do the 'key' work next week, £109.40 inc Vat for the key, £60 inc VAT programming. So decided to get both keys done.
There is also a fault with the motor in the lock. o/s/f central locking motor/lock assembly i part is £135 plus VAT from Porsche, local electrical co to fit £49 plus VAT fitting (hourly rate) Not sure if i will be able to getpart elsewhere, Eurocar etc?
Both my keys need reprogramming apparently
Is it that both keys will not operate the ignition or just that the remote doesn't work to open/close doors etc?
If just the latter (wasn't exactly sure what the issue was) then reversing the battery in the key momentarily
resets the key and allows resynchronisation of the wireless connection. Is reported on the forum elsewhere
and confirmed by Richard I think.
Shame to get new keys if it's just a synchronisation issue.
Dave Jones
Gordon Attar
ORIGINAL: Richard Hamilton
You need new key heads, and have them re-programmed to the car. They can use the blades from your existing keys. An OPC, or any decent independent, will be able to do it for you. They will need to see your V5C as proof of ownership, by the way. They are about £90 each, plus programming.
Ditto
The reprogramming is a 5/10 minute job if you have the key blades, you just need the remotes heads, mine was a touch under £90 6 months ago. Dont forget your PCGB 10% discount card.
