I've been clearing an old unit which my grandad has let me use to keep the porsche in, it's secure and dry and has use of an engine crane too in there which will be handy, i've looked over it all on ramps and over a pit and i constantly question how much money the car will need for me to be truly happy..
I started off with re doing seals on the exterior of the car to keep the weather out, then sorting bulbs/contacts on the dash, window regulator/switches and other small things in the cabin, then mechanical i have no history of the car having a clutch done and i have a slight judder when pulling away and when changing gear so for peace of mind i would like to change it, also i have a small oil leak somewhere on the block, planned to brush some Jizer degreaser on i've bought then find the leak but at the same time, I might as well sort the headgasket out as again, i have no history of it being done.. then whilst i'm in there i might as well give her a full service (belts/tensioner have been done but not sure if i can re use the tensioner once it's been used before, i would have to do some reading up on that) Is there anything else i might as well do whilst in the bay?
with regards to paint i can only really see 2 patches that need doing in the sills, i corner of the sill and some bits under the doors and rear the subframe.. I've looked at a lot of restoration/rebuild threads and i keep seeing people pealing back metal to find more rust.. so i'm nervous i will find this and just want to restore the whole shell lol
Basically.. how far do people go with restoration? Is it just down to budget/time you have for the car or is there a limit to what's worth doing? I could really just do with somebody maybe having a look around the car if possible, if anybody is free i would supply bacon and as many brews/drinks as you can drink (Manchester area)
*The car in question is a 1984 Lux 944, shell and seats look immaculate apart from rust mentioned above a small rip in the drivers side seat, standard cracked dash, 134k on the clocks but loads of history and MOTs to show it's been looked after*
