retro fit Cruise control
- Thread starter 3286ib
AndrewWalling
is this a retro fit item new stalk and perhaps re program?
is it Dealer only or can it be a Porsche specilalist?
Any idea on cost?
any suggestion on where to go in the Leicester area or I am willing to travel for a good deal
Andrew
I spoke to a Canadian dealer to see if they were cheaper - got this back
The cruise control kit (Part 997-044-903-00 )for your vehicle is available in 3-5 business days, and the cost of this kit is $634.24 plus applicable taxes. Thank you for your request.
As a result used parts are a) hard to come by and b) expensive. Needs a linking cable a few screws and either a new or modified lower cowl (I trimmed mine with ease)
I did pay under £100 for the stalk off a crashed 911 Turbo in Sweden
PM if you want more details
Richard
AndrewWalling
Richard where did you get it re programmed and how much?
AndrewWalling
Has anyone else had this problem?
Andrew
1) Complete Control Module Search
2) Code DME
3) Code Instrument Cluster > Vehicle Variants
4) Code Steering Wheel Electronics
5) Ignition Off > On
6) Complete Control Module Search and clear fault codes
AndrewWalling
Andrew
AndrewWalling
Happy days ready for the grand summer tour![8|]
AndrewWalling
Mark Hardy said:I am about to retrofit Cruise control to my 991.1, I have the parts but will need to get it coded. Do you know if this has to be done by OPC ?
It is a very different process for 981s and 991s. I don't think an OPC would be able to code it if you have bought the parts yourself. The way an official retrofit kit works is that the kit comes with a 'licence' code. The OPC enters this code and your VIN into the PPN system, and it generates an activation code. The activation code is entered into the car with a PIWIS tester when the kit is fitted. There are non-offical sources for activation codes (at about $100 US), but you still need to enter it into the car with a PIWIS tester. I have done a few cruise retrofits on 981s, and it is a fairly easy process. If you are in my neck of the woods (Maidenhead, Berkshire) I could do it for you, once restrictions are lifted, or more likely once I get my second jab!
thanks again
Adrian Thompson
Still, good job we are all different!
When I get to the NC500, i'll be driving un-encumbered all the way, no radio, AC or any other driving aid but for the other 1000 miles to get there and back I thought I might make it easier for myself, why not ???
