My 1980 sc has just development a couple of problems :-
1) The rev counter seems to have a mind of its own. I can be sat in traffic, and the rev count will show that I am doing 5000 revs !!. Also the last time it went funny, it completely died, and all the interior lights and radio went off. Is it simply the sender unit that needs replacing, or is it somthing more sinister. I have check all the fuse connections and everything seems ok.
2) How do you change the rear fog light switch. I have taken out the radio to see if you can get at it that way, but it looks as though everything is hidden behind the bulk head. Is it a matter of prizing out the switch with a screw driver or do you need to remove the cardboard partion in the front boot and go in that way. I need to get this sorted otherwise the car is going to fail the MOT as I can't turn the fog lights off.
Any help would be greatly appreciated.
Paul
Paul
