Headed out for a blast this morning, before settling down to watch the GP. I'd left the car on the drive overnight, instead of in the garage. It was a beautiful morning, and with the dew on the front and rear screens clearing as I started off, I thought I was in for a memorable drive.
2 mins down the road, the warning lights in the Oil Temp / Pressure guage flashed on momentarily as I dipped the clutch to change gear. A few minutes later, the rev counter needle died, though the trip computer display continued to work. Then nearly all the warning lights came on including the main warning [ ! ] light. I stopped and tried switching off / restarting. The rev counter flicked into life briefly before dying again. The warning lights lit up again after a few seconds. I turned for home, trying once more on the way to switch off the engine and restart. This time, just the main warning light came on after restarting, but the rev counter stayed dead. It remained like this for the rest of my drive.
Despite the various warning lights, the only obvious (other) malfunction throughout the whole drive was the rev counter.
I've tried the Streather book, but that only indicates potential causes of the rev counter failure (a problem within the rev counter itself, or loss of signal from the DME unit), and the 'xmas tree' effect with the warning lights (ignition system interference with the electrical wiring looms - though the car was serviced a few weeks back, including new plugs and tappets adjustment, this seems a bit unlikely). Unless I'm the victim of an outrageous coincidence, it seems more plausible that the various problems are related. I read in Streather that the Central Informer controls all the warning lights, so maybe this could be where the problems is.
I'm going to try again later on, once it's warmed up, just in case condensation is causing a problem somewhere. As I said at the start, it was cold last night, and I'd left the car on the drive.
Anyone experienced something like this before, or otherwise got any ideas what might be going on?
Thanks,
Paul
Thanks,
Paul
