raoulgough
I have a '95 model 993 Carrera with one reversing light not working. Turns out the ground pin in the lamp socket was corroded through - I've attempted to attach a photo to this post, but if that hasn't worked, I'm talking about the plastic socket with the rubber seal that locates the lamp in place and contains the electrical contacts for the lamp as well. These push-and-turn into place in the central lighting strip with the reversing and rear fog lamps.
So my question is, is it possible to replace the lamp holder(s) individually or do you have to replace this entire chain of wiring and all four lamp holders? I don't see an obvious way that the holder would detach from the wiring to allow single replacements. Also, I can't find any of these parts in the 993 original parts catalog (E_993_KATALOG.PDF), so where would I get the parts for this job?
Hoping someone has dealt with this before...
Thanks,
Raoul.
Thanks,
Raoul.
