clyde
Got home today after taking my car for a quick spin to dry it off after washing it and noted that the reversing lights were on, even with the ignition off and the key removed from the ignition. They were not on when I had finished washing but I do have to reverse it out of my drive so presumably this is when they came on.
I presume that "back up light" indicated in the fuse box lid as fuse number 14 is the one for the reversing lights but removing this does not extinguish the lights. I also tried removing fuse 15 as this is the back up light fuse for an auto but this didn't make any difference either. I don't know where the reversing light switch is so have not checked this. So I have two questions, firstly does anyone know if number 14 is the right fuse for a manual C4 and secondly where is the switch mounted?
I should also say that I did hose the engine down a bit to remove some oil but have done this numerous times without any side effects.
I have disconnected the battery in the meantime but any help would be greatly appreciated.
Clyde
