Revs bouncing
pauljmcnulty
Hi all,
Mine did an odd thing yesterday, then cleared itself and was fine again.
Revs bouncing from nearly stalling, to normal, quite fast, for about 5 minutes in traffic. Oil pressure bouncing with it.
Any ideas? Idle control valve?
That's the best place to start Paul.
Loosen the rubber boot from the AFM to the throttle and squirt some carb cleaner in there whilst its running. If it's only just started sticking this should clean off enough of the gum to get it going again.
