scam75
Well-known member
Afternoon all
My car has started to run quite rich at idle, seems ok across the rev range. I have a scivision so can't adjust idle mixture but car normally idles around 13 on afr gauge. Noticed its down in mid 11's and beginning to hunt a wee bit sometimes at idle. I have checked tps is adjusted ok and it clicks when it should. Any suggestions to try/check?
Stuart
Stuart
