RMS and Tiptronik
- Thread starter Guest
Yes you are correct - RMS appears to be the the most widely used and recognised way to describe this issue across all the sites I read. For information I have a grounding in mechanical matters and am trying to get a better understanding of the problem myself[8|]
If it is a problem with the 996 and Boxster engines ( I can only base my research on what others say) there appears to be a reluctance to accept the matter as a 'live issue' and surprisingly, an even greater reluctance for our Club to ask Porsche for an informed input as to whether they see it as a problem and what they feel the cause to be (materials, workmanship etc).
If Porsche do view it as a problem an idea of when they have a solution to the matter would help everyone - not just now but for many years to come - after all that is what we expect of the cars.
Alternatively perhaps I can put forward the suggestion of 'drip trays' to accompany these models[
keep well
Nigel
I have a Boxster 2 with tiptronic.
here is what I wrote to someone in the club some time ago and still applies.
I took care to run my Boxster S tip as smoothly as possible and I got rewarded with a RMS leaking at 2500 miles. I was devastated as they had to remove the complete engine and gearbox (tiptronic car only) to replace the seal and I thought that they would make a complete mess of it reassembling all of it. But no, everything is still OK.
I agree with some of you that it is how the "robot" assembles the seal at the factory that matters and not how hard you drive the car thereafter. I have since done another 15,000 fabulous miles in my Boxster S and no more leaks (yet!).
In respect of your comment concerning Porsche UK, I have to say that in my own experience Reading provided me with every assistance last year on issues that I thought they may very well 'wince' at.
As yet I have not tried them over the RMS issue - I am still uncertain as to the extent of the problem following a suggestion that 03 and later models are no longer affected.
As a matter of interest there have been very few engine failures that I have come across in my research - and finally was your letter formally from the Club or as an individual owner?
Nigel
OPC's don't want to do it on warranty and will not guarantee their work when they do it. This is totally "pie in the sky" as a good solicitor or trading standards officer will tell you. So don't take no for an answer.
With my previous Porsche (996 Tiptronic - 2001), I've got the RMS changed @ 35,000 miles (4 months before the end of the warranty).
Porsche Centre Reading (formerly AFN Reading) agreed it was a problem to be fixed under warranty...
Anyway, since it seems to be a common issue this problem should fixed Free of Charge, even after the warranty's end.
On a global basis I do believe PCGB should put some pression on Porsche UK... and Porsche Germany.
Cheers,
Fab
I am new to a 996 and am not sure what the RMS problem is your talking about and what I should be aware of.
I have just bought a 996 98/R C2 Tiptronic with 89k on the clock from a specialist dealer.
Also, has a puncture last night and has damaged the sidewall. I need a Pirelli P zero 265*35*18 N3 and the car is in Grays/Chafford Hundred but amd going back to Wanstead/East london.
Cheers,
Rob
There are numerous theories as to why they leak ranging from the material used - the manner of fitting - the manufacturing processes of the engine etc. At the moment only Porsche really know what and how large the problem is.
Remedy is a new seal which costs between £250 - £500 to fit. Porsche will carry out the work on occassions at no cost even outside the warranty period. Extended warranties generally do not cover the seals. In the States it seems that they replace the seal once and if it fails again Porsche swop the engine.
Like many others I am keen to get a better understanding of the situation. Seals should not fail in the manner that these are and if they do IMHO Porsche should be looking to remedy the situation and in the meantime have consistency in their approach to free relacements.
It would be nice to hear the thoughts of someone at Porsche (via the Porsche Club GB) but at the moment nearly everyone affected seems happy to do a 'Nelson'.
