Road legal track car -advice needed..
- Thread starter Axl Rose
Neil Haughey
Neil Haughey
Axl Rose
ORIGINAL: Neil Haughey Well following on from what John says what about the heater? ISTR that a road legal car must have a means to demist the windscreen therefore needing a heater and fan. Would this be looked for on MOT test though? Glass windscreen as well of course but starting to move away from interior.
edh
You don't need a speedo / odo - my Fiesta didn't have one & passed OK. Hazards required for cars later than 1986.ORIGINAL: John Sims Rear view mirror, a method of recording mileage and speed, a functioning parking brake, road legal lights, indicators, hazard flashers and a horn, seats and belts as noted above - otherwise just a racing car.
944 man
944 man
Am I the only person who took this to mean: 'I want to be able to still carry a passenger in my track focussed car'? Hence my "seat, belt and passenger door that opens from the inside" reply...ORIGINAL: Axl Rose Has anyone got a street legal track car? What are the vital elements in passenger department to pass MOT as a street legal car?
Axl Rose
Axl Rose
ORIGINAL: 944 manAm I the only person who took this to mean: 'I want to be able to still carry a passenger in my track focussed car'? Hence my "seat, belt and passenger door that opens from the inside" reply...ORIGINAL: Axl Rose Has anyone got a street legal track car? What are the vital elements in passenger department to pass MOT as a street legal car?
944 man
Axl Rose
ORIGINAL: 944 man Harnesses may not be good enough. For an MOT you need an 'E-Marked' harness, which will probably be a 2" four pointer with a seatbelt type buckle. Conversely for protection youll want a 5/6 pointer with 3" webbing and an aircraft type quick release buckle. Non-E-Marked harnesses shouldnt pass an MOT so you have to choose: either retain the seatbelt and use a better harness or remove the standard belts and replace with an acceptable E-Marked harness. Simon
Hilux
So true, have you ever done a cold wet track day with no heater/demister?? Alternative is an electric fan heater designed for the purpose, small, light and removeable on hot days.You dont need a heater, although in my personal opinion itd be a folly to remove/disconnect it, unless you have to seal the bulkhead. Even then a race car will still have it in order to demist on a wet day. A road car must have a demisting device, as stated above.
Unless you need to use them for a very good reason then try and avoid the 4 point belt buckle types. They are cheap but you get what you pay. You also cant get out of them when upside down!! Use a quick release type harness where all straps release and 3" shoulder straps which spread the load better. For an MOT simply bolt in the old seatbelts - its 15 mins work once a year.I've already removed the standard belts and just fitted E(4) 4-point harness with seatbelt type buckle..used standard mounting points for both, front and rear..the harness i used came out from my '86 Alpine White..although personally i didn't think it was fitted up to standard and rather unsafe (front point were mounted onto bolts that were welded onto the sides of base frame/sliders not chassis!!?!, rear points were joined and bolted through floor using just a bolt and nut!!) it still passed MOT..[:'(]
....or fit a heated front screen - gets rid of a lot of heater system weight. [ORIGINAL: HiluxSo true, have you ever done a cold wet track day with no heater/demister?? Alternative is an electric fan heater designed for the purpose, small, light and removeable on hot days.You dont need a heater, although in my personal opinion itd be a folly to remove/disconnect it, unless you have to seal the bulkhead. Even then a race car will still have it in order to demist on a wet day. A road car must have a demisting device, as stated above.
944 man
944 man
[ORIGINAL: 944 man ...you can even run without lights if youre happy to opt for a 'daylight' MOT...
