Every so often I remember that there's a rocker switch and a small red light on the right hand side elevation of the centre console (i.e. the switch faces into the driver's-side footwell). There are also two pozidriv-head self-tapping screws which hold the carpeted panel (about 5" x 3") on which the switch and light are mounted into the console. It's clearly a factory fitted item.
Does anyone have any idea what this switch actually does? If you switch it on with the ignition on the light flashes but nothing else happens so far as I can tell.
