colin smith
I've noticed that occationally when closing the roof the plastic wire/ edge of the fabric doesn't alwats sit behind the plastic edge. Is this a easy problem to sort , I've had a look but can't see how you tension it.
ORIGINAL: blaster56
This may be of some help; I fixed this very same issue with my Boxster's roof(2007 987 S) earlier today.
If you open up the roof about 2/3 of the way back, you should see (feel) that inside the roof, about 4" up from the bodywork, there's a triangular piece of webbing with a piece of elastic attached. The webbing goes from just inside the beading towards the inside rear of the roof covering. The elastic, which is slotted, is half an inch wide and about 5" long. The elastic is attached/screwed, through one of the slots, to part of the roof frame with a small Torx screw.
If the elastic has stretched, possibly through age, it doesn't have enough tension to pull the plastic bead into the roof slot. When you try to close the roof, sometimes the beading stays on the outside of the roof frame and doesn't sit in the slot.
You can shorten the elastic, by undoing the screw and refixing through another slot. In my case (no warranty), the elastic was shot so I went to Cridfords, a local Indie who sold me a new piece of elastic for £3. Cut in half, it's long enough to do both sides. I undid the screws, cut away the old elastic and sewed on the new elastic. If you can sew a button on a shirt, you can fix this. New elastic is not slotted, but poke a small hole and the screw pushes through. Re-attached the screw and job done.
There's a soft top roof company near Chessington who offered to fix the problem for £75 a side. Saved myself £147 !
Biggest problem ? You really need a short Torx screwdriver, as its a bit tight between the room frame and the inner roof lining.
