Typical Porsche over engineering - With my Capri you would unclip the distributor cap, lift of the rotor arm and replace it - Not on a Porsche you don't [
OK guys what is the secret? I fiddled off the distributor cap - a pain in the bum by its self - and find two fixings into the shaft:-
There is an allen bolt and an 8mm hex head bolt.
The Allen bolt is on the shaft of the new part as well so I assme you leave this alone. I did undo it on the new part, to see what happens, but it didn't achieve anything so I put it back again.
The hex head bolt is just under the edge of the aluminium casing so you can't get a socket onto it. it is also slightly recessed into the curved shaft so not ideal to get a ring spanner on to. I tried an open ended spanner but this was looking as if it would round off the head so I gave up on that.
Any ideas chapps?
Any ideas chapps?
