ROUGH RUNIN C4
HI GUYS HOPE YOU CAN HELP ON THIS ONE,MY C4 IS PLAYIN UP SLOW MOVIN TRAFFIC SHES VERY ROUGH NOT SMOOTH AT ALL AND WHEN TICKIN OVER ITS NOT STEADY GOES UP AND DOWN NOT A LOT BUT UP AND DOWN ALSO STARTED TO STALL WHEN COMING TO STOP ANY IDEAS???
Try all the usual basic stuff first. Check your battery is in good condition. Check all connections in the engine bay for tightness. Check your dual distributer, make sure that both rotors turn (no broken belt) etc.
Also possibly the O2 sensor on the exhaust system, this plays up on some cars at this time of the year (damp).
Mine had a bad idle which was the idle microswitch, the switch is where the throttle cable returning hits the stop, its tiny but you can hear it click with the engine off if you listen carefully
see my post here for a pic that im talking about
http://www.porscheclubgbforum.com/tm.asp?m=82481&mpage=1&key=microswitch&#82521
