RS Centre Section
graham harvey
Club Member
Hi,
Has anyone purchased one of these from Pro-9? They are only £89. I don't want to dismiss because of the price but usually things are cheap for a reason.
Graham,
As you may know, I have a Pro-9 body kit on my car. Firstly, their parts will be fibre glass, not moulded polyurethane as the factory parts are. Fit will be a bit hit and miss although the overall quality - given it's fibre glass - will be OK. You'll probably have to make the cut outs for the number plate lights and tow hook yourself and there won't be a covering for the tow hook hole - if you make one. I think that's just about covered the reasoning for the price!!
Dave
thanks Dave, I remember seeing your car at JZ a few years back and was impressed with the quality. Not sure my skills are up to doing so much required work. Still in two minds if adding the rear section is worthwhile.
