Has anyone replaced the standard clutch/flywheel with the RS version. Mine is coming up for replacement and I am thinking of going this route. I know it makes more noise on tickover, but have been informed it improves engine response and makes it feel more lively?? Anyone tried this?
RS Clutch and flywheel
- Thread starter Chris_James
scaramanga
sorry i can't offer any opinions, but i'm in the same position so would also appreciate any views...
oliverjamesthomas
It can cause stalling problems, but we're not talking about every dip of the clutch. I think the problem mainly happens when the engine is cold, funnily enough. Wayne can map the ECU to make the situation better, but the only way to stop it completly is to go with MOTEC or similar, I understand.
I've got one on mine and yes, there is a bit more vibration, but considering the difference it makes to the way the engine spins up, I wouldn't be without it.
Thanks, sounds a generally positive move. Does anyone have Wayne's contact number?
911addict
Don't know about 993, but my turbo has LWT clutch/ flywheel package, and no stalling issues, no noise, and improved response. There are several tuners who do flywheel packages (I used Patrickmotorsport in the States) so shop around and go for one that others have used without problems.
