Some of you are probably aware that I had a minor stub axle issue at Spa. As a result the kind guys at speedservice fitted C2 parts overnight. Post Spa I've bought replacements RS parts to convert back to original. However, on discussion with a couple of you here, and seperately with my garage, I've been told that the RS part was lifed - but nobody seems to know for how long. As a result (and with a trackday booked 18th May (silverstone new gp eve. )) I've decided that the other side must come off. Now, as I've got C2 parts and the because the RS parts are pricey I'm going to fit the C2 parts to the other side for now.
A little background for those that dont konw. The C2 shares the same parts as the Turbo (I believe), these are steel tension bolts with seperate ABS wheel and steel wheel carrier. But the RS has an an ali tension bolt with built in ABS wheel, that mounts to an ali wheel carrier. These use an additional spacer but the same bearing. The key difference in the tension bolt is that locator to the wheel carrier is hex, where as on the C2 is round and just and interference fit. Quite why this is I'm not sure (linked to centre lock wheels?). Both are torqued to the same degree 399lb/ft or FT
So my question is what do I do next. here are the options.
1) replace the C2 parts with RS parts (swallow the cost) and replace at undertermined interval (say every year?)
2) replace RS parts with C2 parts (not lifed, and cheaper), although I need to buy a wheel carrier in addition. however, once I have the wheel carriers, tension bolts and wheel bearing are cheap so could be replaced annually with out issue.
Now I know alot of you have tracked these cars for long periods of time and never encountered this, but a quick conversation with a mechanic who helped run an NGT in a race series, and he said "yeah that happens", and I'm keen not experience that again - as the outcome could a be a little worse.
Also does anyone have any information on what else might be lifed on the car, or if indeed they were lifed. Hard to see how they lifed parts on a road car, when it does nt seem to appear in the service schedule?
Anyone shed some light or offer an opinion?
