Morning all,
I have been looking at a few cars in Europe and have come across one that originated in Japan. All the other cars that I've seen so far have the VIN plate located on the off side inner wing above the chassis leg at the front under the bonnet.
The car from Japan does not have the plate there - were they ever located elsewhere or is this likely to indicate repaired accident damage? I know that not all 964's have the plate located there, but not sure if this is the case with the RS also.
The car looks very good and if it has been repaired then it appears to be a very good job. There is no question that the car and shell are genuine RS, and that the VIN is correct for the car. If it should be present and is indeed missing, is it possible to obtain a new VIN plate for the car from Porsche?
Jon.
Jon.
