nineonetoo
Hi guys...
I've noticed recently that my rs is moving around under throttle application. It tends to pull to the right under throttle and then back the other way when i come off the gas. I've had a couple of suggestions from the diff (as far as i'm aware its the original item - 45000kms) to kinematic toe and bushes etc.
i track it quite regularly and I only seemed to notice the pull when i went from street tyres to pirelli semi's. I had a good look under the car today and non of the bushes look shot (would you expect any movement at all from the bushes!? lower arm seems to have a small amount of side to side)
Tyres are new....Pressures are the same...Suspension set-up done a while back but the car didn't suffer from the complaint when it was done.
on a separate note ive got a really annoying squeek from the back....sounds like little people! drives me bonkers!
Apologies for the questions but being in dubai means people with the required knowledge are thin on the ground.
Cheers, Phil
Cheers, Phil
