RS Spyder Wheel
- Thread starter stevered
You are fortunate to have ceramic disks... and good to use wheel wax
I try to just use soap and water and occasionally cleaner , at the moment I am using Porsche wheel cleaner from my OPC which is expensive but I don't use that much and if it caused a problem with the finish I would go and knocking their door.
If you have time it is worth polishing with Rim Wax or similar after cleaning-
I do find cleaning the inside ie behind the spokes frustrating because as soon as I go for a drive to dry the discs you get grey wash off over the area again.
They do look great when polished up though.
Tony
STiG911
One can will do 2 car sets worth of wheels and the results are ace, with minimal brake dust sticking to the rim (he's got standard brakes, not ceramics) and they're also far easier to clean too.
The key is to get the wheels as clean AND DRY as possible before applying for the best results - it works fine on any wheel finish, but seems very popular with owners of black rims.
RussellFunnell
