rs steering/suspension alignments
- Thread starter Guest
the car has the m030 springs on it already (factory fitted) - which i believe to be the same set up as the turbo?
going to bilstein sports (HD's are the US name - actually sold here by bilstein uk as sports).
dont want rs ride heights want to stop with the m030 height.
all i was really interested was the differnces in camber and toe in and out setting as the corner weights will have to be Carrera 2 and ride heights as per m030.
may just go for c2 setting for now to see what direct effect the billies have
marc
38F3E1
ORIGINAL: porkapig
No. The turbo springs are harder.
If you have M030 springs on the car I see no reason to change these unless they are worn out. I have heard of dampers wearing out but never springs. M030 springs go well with Bilstein HDs.
Ian.
yes indeed i am experimenting - my last car lancia delta evo was played with quite a bit with some really good results handing wise (renowned to understeer alot standard - playing predominantly with rear toe in and increasing front camber made it miles better) however with much worse tyre wear.
in regards to anti roll bar - yes leaving it standard from my experence best to play with ARB last
kinematic toe - yes will be checking it when set up
agree with your comment re experts selling techniques....
algray
but I understand the standard version may not even allow RoW M030/M033 (certainly not RS) without modification. This is why Gert sells the extra thread version I mentioned.
Maurice is correct about this, Bilstein HD will sit higher than M030/M033 height, to achieve the M030/M033 and RS height you need Bilsteins HDs with the extra thread.
AG
ORIGINAL: algray
AG
yes i have read that too - 10mm apparently higher, which to be honest doesnt really bother me - if anything would prefer a slight lift for clearance purposes. in reality 10mm wont even be noticed visually or handling wise on the road IMO
will share my info once i get it back
marc
