bennyboy
Evening all, will finally get around to removing my side rubbing strips when the weather perks up a little. Went out to take a look tonight and just wanted to double check something as it hasn't been mentioned before, that I remember. I was under the impression these just pull off with some heat applied, however, the strip on the door itself actually folds round the edge of the door at the handle end and is secured with an allen key bolt. Is this the same on all 944's? Thanks, Ben
