Tuppence worth from a Targa owner... Nothing wrong at all with the Targa option provided you check a few things first (in addition to all the standard checks): - Does the glass roof operate correctly/smoothly, no noise from the motors, etc. - Does the roof seal correctly (and no leaks)? Check under the front foot well carpets to see if the foam underlay is damp. This is usually a very good indicator, and there can be a lot of water in there in the worst cases. If it does leak, you'll need to find someone who knows what they're doing to realign the roof. - Does the sun blind work? Operate it backward/forward quite a few times to check. Whoever designed that mechanism needs some serious help... - Does the air con work? Important if you're sitting in a glasshouse! However, if all the above checks out then the Targa can be a great option (which is why they often attract a slight premium). I've been perfectly happy with mine (since having the roof rebuilt ~£150 to stop wind noise and a slight leak), and the noise really isn't bad at all with either the front flap or the roof open. Far better than my wife's convertible, which requires deflectors etc. to make it bearable. Yes, the weight may be a little above standard, and the chassis slightly more flexible, but how often will you be on the track - and how often will you be motoring along on sunny days with the roof down listening to the engine...?! Running costs are what they are with this type of car. Get a good car with solid history and no major work coming up (brakes, clutch, rusty screen scuttle, etc. etc. etc.) and yes, you can run it for around £300 - £400 a year. Personally I would budget more because with a car that's getting on, there are always going to be a few things that need doing, whether cosmetic or mechanical. And like most 993 owners, you'll end up going down the same path. "Well, the car's pretty much sorted now. Although, those seats, aren't quite up to scratch. Maybe I'll get them re-dyed. And while I'm at it, the dial surrounds would look better in chrome....". Have fun choosing. Cheers/John
