plhorner
Moderator
Right, I could really do with some help on this one.
I had SSI's fitted over the winter, the job took about 12 weeks longer than anticipated which left me little time to get my brakes re-build before Le Mans. Anyway, I finally got some miles on the clock to settle things down prior to going back to the specialist to have the mixture adjusted once things had settled down. Anyway, the car had been running really well, however when we put it on the analyser we found it to be running a little lean. The chap at the garage started to adjust mixture and turn the slow running down, we got nearly there and then found that the engine wouldn't rev. It ticked over just fine, but open the throttle and you could hear the induction roar but the engine just spluttered badly. Said specialist diagnosed air flow meter problems, adjust things back to where we had been...but not quite! On the drive home, on very light throttle openings, the car hesitated, if I put my foot down it would surge forward after a slight pause. Anyway, for various reasons I had to leave the car for a couple of days after which it appeared fine and I couldn't repeat the fault. Said specialist reckoned it would be fine for the trip to France......I only got 15 miles before it finally packed up (and fortuately this side of the channel)!
So symptoms are: When fully warmed up (after 15miles / 10/15 mins) the car hesitates and sometimes looses all power. It won't stall and it ticks over fine, how ever if you put any load on the engine it really struggles. If you lightly touch the throttle you can get the revs up and it will go, if you really get the revs up it feels like nothing is wrong! If you floor the throttle from tickover, the engine coughs and won't pick up.
I've had the airflow meter out and checked by a bosch specialist, apparently fine. I've done the checks in the Bentley, I've got power to the meter and the temp sender is OK and in spec.
Having had a look at the engine, it appears that a new cylinder head temp sensor has been fitted recently (without my knowledge - I've had the car 6 troble free years!) ANyway, the sensor is the new 2 wire variety and is in spec. resistance wise.
Could it be a dicky DME relay? Fuel pump dying? ECU failure??
Really lost now and don't want to take it back to the specialist, lost a lot of confidence in the place and feel like I've been spun a yarn or two....I'll say now more!
Help, all ideas greatfully recieved!
Cheers,
Cheers,
