Running rough (cold)
- Thread starter Patch234
A fuel pressure leakdown test might shed some light.
Failing that, check condition of dizzy/rotor/plugs.
Failing DME temp sensor can also cause rich running, easy enough to test, or cheap enough to replace if suspect.
Does this clear soon after or once revved?
A visual check in the dizzy cap, rotor and plugs will be easy enough - contact points on cap & rotor should be clean, without excessive pitting/wear. The plugs should be tapped correctly, and a mid brown colour.
To test the fuel system you will need a fuel pressure gauge - there is a write up on Clarks garage website to check fpr and also a leak down test.
The DME temp sensor can be checked in hot/cold water by testing resistance at different temperature, there is a chart online for the sensor - I have it somewhere. They are fairly cheap though, so if no record of it being replaced it wouldn't hurt to change it anyway.
Patch234
edh
http://www.clarks-garage.com/
