Rust protection for sills.
- Thread starter white944
cococola
I did mine so that it dripped trough the drain holes and after a couple of days,make sure that these are unblocked.
I retreat mine every couple of years which maybe overkill but makes me happy. []
MartinRS2K
As said above spray liberally into the sills via the back vent and lift the carpet to get access to the plugs that left out to let you spray in there until it comes out of the drain holes and after a couple of days the drips will stop. I do it every Winter.
http://www.ebay.co.uk/itm/like/320863736479?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=t&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
ORIGINAL: Richair
The Bilt Hamber stuff is also supposed to be good.
Yep, I use bilt hamber dynax s50 - same process as described for the Dintrol cavity wax.
Mick
