hi there can any one tell me why the discs on my boxster keep rusting when its been raining or when i wash my car i always take it round the block to dry the discs of but the next morning thay are red rusty so when i take the car out the noise from the brakes drives me mad is any one having the same problem thanks
rusty brake discs
- Thread starter byron
garyw
Moderator
[link=http://wiki.answers.com/Q/What_is_rust_and_how_does_it_occur]http://wiki.answers.com/Q/What_is_rust_and_how_does_it_occur[/link] [] The whole Porsche range suffers from it.[] It may have something to do with possibly a higher Iron content or something within the discs..[&:] I see your doing the right thing though to try and limit the build up by driving the car after cleaning etc... garyw
It's the lack of chromium in modern discs that's the problem.It may have something to do with possibly a higher Iron content or something within the discs
Water holds in the holes then trickles down the back of the discs. It takes a decent run to get heat into the discs to remove this. It tends to affect cars that aren't used much, especially if they are cleaned then put away. Inside rears are the most vulnerable Spec the lovely ceramics next time []
My car sits in the garage for weeks on end. I always worried about it causing a long term problem, but it never has. Once I run up the road and back it's all gone. I remember the first time I used the brakes after long term store you could hear the brakes make a noise. I took a look and the disc's all look new again but you can see the rusty dust as it's been taken off by the pads. I guess it's just one of those things.
Harrington
I've just had to have all my discs and pads replaced as they had excessive corrosion on the discs, especially the inside edges which are difficult to inspect other than crawling underneath or on a lift. I was told my the dealer that the corrosion was normal due to the fact that a high proportion of the disc was iron. Asbestos used to be used but this was removed for obvious reasons. I was also told that washing my wheels and leaving the water to sit in the discs hadn't helped so I clean them very carefully now and just use damps clothes rather than a wheel brush. I've only had my Boxster for a year so wasn't too happy being presented with a bill for over a grand for just the brakes! Never had to do that before with any of my other cars (non Porsches) so perhaps they have a higher iron content than other manufacturers. Just waiting to see how long these last now that I'm being more careful what I'm doing! Who'd have thought that cleaning your car was a bad thing! Ro
How many times have we heard this story ...your brakes are corroded sir we advise you replace them now!! thank you will get them attended to but not today and not at a grand thank you ...replaced my rears for £300 using porsche genuine parts from the opc inc fitting Most owners complain about the brakes and rust nothing new
