Rutland, sells, wants and swaps
I'm after a rear seat base - ideally black cloth or cream/linen
Now I've fitted a more solid gearbox mount it's a bit more noisy in the cabin..
I've also got a few spares I can stick in the car..
S2 head - no cams & tensioner (Also have the block but I'm not bringing that [:)] )
Sunroof bag
Washer bottle & pumps (late style)
Rear wiper motor
S2 Alternator
S2 exhaust manifold
S2 ABS ECU
Turbo wastegate
email or pm me for more details
Hi Edd,
I'd be keen on the rear wiper motor if the spline is good.
I have:
Ashtray for centre arm rest.
Set of std rear shocks for 944 turbo about 8 yrs old with low miles. I replaced them in error trying to trace a noise from back of car.
2.5t halfords trolley Jack. Used but Working condition. Quite low - Just not quite low enough to get under my lifting points without driving on to a bit of wood.
Be aware that the rear wiper motor will be different if its off Eds 1990 S2. Smaller hole in the glass and smaller splined shaft that 1988 and earlier types. 1989 is the changeover year.
ORIGINAL: edh
Sent you a PM re the block but it's not appearing in my sent folder, did you receive it ?
I want a day free of other stuff so I can join you lot. I'm a bit jealous ....
Ed, I may be interested in that S2 head from you as a swap for mine, as I'd like to take mine off and rebuild it. Having a spare would enable me to rebuild the spare and have it ready to swap, meaning less time off the road. I'm up in Derbyshire occasionally so could pick it up ... I'll PM you.
I have linen vinyl off the centre arm rest available and black vinyl that covers the sunroof panel both in good condition.
I also have a cycling valve and a sunroof motor if anybody is interested.
