Ruuning Without a Balance Belt...
- Thread starter 944 man
Rob
Caveat above as it's all received wisdom; I ran my balance shaft after the research so can't speak from experience.
edited for typos because I'm sloppy
944 man
Of course on a track car that is all less relevant as well as less likely due to the normal operating range of the engine speed.
944 man
The oil pickup develops a crack where the pipe meets the base, sometimes starting as hairline and growing, sometimes just a big catastrophic failure.
jr2015
If you want to go faster with reliability, why not remove weight? It should be possible to get the same ammount of increase in performance without sacrificing reliability.
jr
pauljmcnulty
later taken up by Mitsubishi
And Porsche had to pay a royalty for every engine using it apparently. [8|]
944 man
Without acid dipping it, the car is already about as light as it can go. Its a non-sunroof car: polycarbonate windows and hatch; rear wiper removed (obviously); window regulators & motors removed and metal removed from the doors; all carpets and sound deadening removed; 5.5kg composite seats replacing the originals (one only fitted atm); rear seats removed; electric hatch release removed; all of the tyres have been treated and the spare wheel and tools have been removed (but Im running with the spare again as the back was sat up like a dragster!). Further to this the car has lightweight GRP front panels, a lighter exhaust and Im just about to drill out the rear compressed fibre bumper..... I intend to replace the rising lights with fixed GTS-type parts in the near future, as soon as I can successfully form a pair of covers (this is one of the few instances where Perspex is better than polycarbonate, which is hygroscopic. No matter how carefully I think Ive dried the bast*rd stuff, it keeps coming out of the oven full of bubbles!). The only other things I can think of are a lighter 35ah battery (planned); 8" & 9" Fuchs (far too expensive now) and removing the rear speakers. Im reluctant to do this because my iPod wont turn up loud enough to drown out the ringing in my ears, that Im suffering from driving such a noisy car.....
It has been suggested that I could lose 20 kilogrammes myself too, but thats not quite as easy.
944 man
ORIGINAL: pauljmcnulty
Porsche more than broke even with the Tiptronic royalties, I believe.
Lanchester invented the balance shaft, but Mitsubishi patented a unique and original variation. I believe that Porsche developed their own version (which would have been royalty free, if not patentable itself), but the two bearing Mitsubishi version perfromed better...
pauljmcnulty
I'd enter it for the National concourse.....[8|]
sawood12
ORIGINAL: 944 man
He also invented the disc brake!
Not in time to prevent the untimely death of James Dean apparently, who cancelled his order for a Lotus that was the first car to have disc brakes because it was taking too long and got the drum braked Porsche in which he ultimately crashed. I don't think balance shafts would have helped him though.
The balance shafts are not there just to reduce vibration for comfort reasons, but also to reduce the stresses and loads on the rotating masses of the bottom end. Running any machine in an out-of-balance state is not a good idea and certainly not worth a measly 5hp and a few KG. You will not notice 5hp and a handful of KG in the dynamics of the car. What do you think the increased vibration is doing to the loads of the piston rings against the sides of the cylinder walls? or the increased load on the engine bearings.
sawood12
