Been tracing down oil leaks, sense I removed the metal undertray to do the level sender which iv still not done yet iv noticing a few drops off oil.
First seems to be from new turbo drain line. Which considering it don't mount by the drain should off been less likely to leak.
there's another on the other side which looked to be cam cork gastic do I nip that up a little more, but now it's the rear off the balance shaft plug.
What's people's thoughts on rvt used on the outside? Save the balance shaft reseal and do with sump and rod bearings later on.
