S Wales - Dash Cam fitment
- Thread starter 911dbx
Thanks Jon - which camera did you go with?My one month old 4 GTS had the pre wiring in situ for the Porsche dashcam. Installation was simple and straightforward. No need to run cabling to the fuse box
thanks
Did you fit it yourself Jon?My one month old 4 GTS had the pre wiring in situ for the Porsche dashcam. Installation was simple and straightforward. No need to run cabling to the fuse box
There has been a lot of problem with the IQ especially the rear camera. It has been on going since November and the latest firmware 1.7.6 seems to have sorted the problems out. When it works, it is a very complex piece of equipment but very good. Easy to fit, just use the OBD connection.If you have not done so, the Nextbase iQ (it's a smart dash cam) is worth considering; retails at £600 for the pair (before discounts) and a choice from 3 monthly plans are available. Comes with a plug which connects straight into OBD port.
