S2 cam refit.
colin944
When fitting the cams on an S2. Should you use a bit of locktite on the bbolts that hold the cam in. The torque spec is 20nm. Is seems very low and I'm worried about them working loose. Anyone done this job and if so did you have any problems.
These are the bolts on the cam caps, non?
I don't think I used any loctite on mine and all seems fine thus far, 4 years later!
Yes cam caps and also the bolts on the chain tensioner. The tensioner bolts are only 10 nM. And they had worked loose and caused the oil pipe to break. I had to drill and re-tap them,so I'm a bit a paranoid about it doung it again.
