My S2 has started to cut out at low revs for example having come to a stop at lights whilst it will tick over ok when you pull away the engine dies it is also misses quite badly when driving at under 2000 revs if you are doing 30 to 40 in fifth it Kangeroos along rather than driving just steady. At top end it seems fine it still accellerates like a train and I left an old impreza in my wake the other day so I am happy with that side of things. I have also noticed that it is a reluctant to start now it's getting colder but is ok once the engine has been running. I recently changed the dizzy cap and the MAF, injectors are working fine and I have sorted out some cracked hoses tp the manifold so I am happy that it is not any air leaks. I also bought a new DME relay which has made no difference.so I am thinking possibly the engine temp sensor. This is perplexing me and any advice what be appreciated. Thanks.
S2 dying out at low revs
- Thread starter 944cop
BlackMagic
I had this problem a few months ago.....fortunately just before it was about to go into a well known indie on the south coast. The switched the throttle position switch and all is now well again.
I cant promise, but it is reasonably cheap and easily accessible. Maybe borrow one from a friend to see if it makes a difference before you buy.
William
William
alwigley
Could well be DME temp sensor - caused mine to idle very low and cut out, but started off as a minor nuisance and got proressively worse. Checking it with multimeter was tricky as seemed to be an intermittent fault. Sensor is only about ÂŁ15 from ECP, and changed in minutes if you have the right (deep) socket.
TPS is on the buterfly where cable mounts , any sensor on engine thats faulty will cause these problems , also fuel presure to high or low , dont forget rpm sensor on flywheel , had a golf gti few years ago and ht leads were failing caused this fault but would clear at high revs , i changed plugs and it was ok for 2 days then fault returned
peanut
my guess would be the engine temperature sensor too.
If the car runs fine when hot it probably is.
The only other thing I can think of is the auxillary air valve.
Might be worth checking the cold start injector also .It should give a squirt of fuel on cold startup.Make sure the electrical connector terminals are clean .
If the car picks up well with a squirt of easy start when cold then that would suggest a fuel starvation issue due to the cold start injector and or engine temperature sensor not working.
Wot Peanut Said. ^^^^
The only other option would be to carry on looking at the HT system. I have had similar symptoms on a Golf - very sulky at low revs, fine at high revs. Turned out to be a dizzy cap tracking. You have changed yours, but how old are the plugs and what about the leads/dizzy arm? All worth a good check.
peanut
ORIGINAL: zcacogp
ahhh...... you say the nicest things .......are you looking for a loan ? or a drive of my car lol[
peanut
ORIGINAL: zcacogp
Just suggesting that grumpy old farts say things worth listening to! []
(You have the same car as me - an S2, but mine's better - and I thought you were broke anyway? [] )
I might be broke but mine's the better car you young whippersnapper you.[
Now now, let's not have dissension over minor differences between the superior 944's. We can save that disdain for the owners of the turbo models - poor slow chaps that they are! [ORIGINAL: peanut
I might be broke but mine's the better car you young whippersnapper you.[]
peanut
ORIGINAL: zcacogp
yes you're quite right. They'll probably never know the bliss of owning an S2....... in their blind pursuit of speed and power[
'More power Scotty........ we need more power' I'm giving it all we got now capt'n etc
Outrun944
ORIGINAL: peugeot
Not sure about cold start , my s2 used to do the same thing .I carried out repair to air flow meter (youtube),tracks worn.
Now driving perfectly.
Is this the YouTube vid in question?
http://www.youtube.com/watch?v=-11J8XawQtc
