Chaps,
Maybe this is the first contender for an FAQ thread, here goes ...
I need to replace the disks on the front of my S2. The manuals say that new disks are 28mm thick, and minimum thickness is 26.6mm. So, 1.4mm wear allowed.
I measured the size of the lip on the outside of the outer face of one of the disks on my S2 last night (easy to get to, just poke the vernier through the lovely D90's *) and took five readings of between 1.05 and 1.15mm. So, double this (two sides) and this suggests that I have total wear of over 2.10mm. So, the disk is past it.
New disks and new pads are therefore order of the day. So, some questions:
1. The manuals seem to suggest that it is a simple job replacing the disks and pads. Pads don't worry me, but the disk is a case of caliper off - two retaining screws on the front of the disk off - remove disk - replace disk - screws in - replace caliper - fit new pads. Is it really this easy?
2. Is it worth having a look at the adjustment of the hub while I am in there?
3. How long to front disks last? I know this is a "how-long-is-a-piece-of-string" question, but the car has 140k on the clock and I can't see anything in the history that suggests the disks have been changed. Is this possible?
4. I have ended up with Mintex pads. Are they OK?
5. What is the recommended procedure for wearing-in pads and disks? Should I avoid hard braking for some time, or actively seek to bring the car to a sharp stop from a high speed to bed them in?
All advice appreciated! Thanks ....
* - For Nick, just to underline my appreciation for the D90.
(Anyone who mentions Seat's, diesels or welly boots in their reply will incur my eternal wrath. I hope this is clear. OK?)
