S2 Head Swap
zcacogp
Some of you will remember a bit of discussion a while ago around these parts about rebuilding cylinder heads for an S2. My S2 is about to tick over 195,000 miles and, given concerns about both frilly head gaskets and lost ponies, I decided to take the plunge and get it done. I bought Ed's (edh on here) second-hand head that he had thoroughly ruined on his S2 track toy and had it rebuilt by Ivor Searle (http://www.ivorsearle.co.uk/) up near Cambridge. I can't remember the exact details of what they did but I think it was a case of a clean-up and re-face, 8 new exhaust valve guides, one or two new valves, re-built tappets, re-ground and lapped in valves plus a set of new valve springs plus probably a few other bits and bobs that I've forgotten. Tom (MonkeyThree on here) had his head done by Ivor Searle at the same time (in fact he found them and made the arrangements, as well as collecting my head and bringing it down to London for me - thanks Tom!)
I swapped my old head for the re-built one earlier on this week with the help of a friend who has a good workshop with air tools. It took the two of us a fairly long day, although we could have gone quicker had we not stopped for tea and biscuits and other distractions. There are some very good guides on how to do the job on the internet, mainly the various procedural write-ups on Clarks Garage (http://www.clarks-garage.com/) and the Porsche manuals (which every 944 owner should have - eMail me if you want a copy.) However there are some points that aren't covered in the guides, as follows;
- Undoing the six bolts on the two flange joints at the bottom of the exhaust headers has potential to be difficult but mine came away fairly easily. Thinking about it, they were removed when I took the exhaust off to do the clutch about 6 years ago so they weren't 25-years old. I soaked them as well as all the other fasteners in penetrating oil several times over the few days before the job to ensure that luck was on our side.
- The guides suggest that it's easier to remove (and re-install) the head with the exhaust headers still attached. As it was we removed the head with them attached but when it came to re-fitting time we put the headers back into the car and put the head back on the block and then bolted the two together. I think this was easier but your experience may be different.
- The inlet manifolds are a pain because of the injector connections. I know that Tom struggled to get his injectors out of the inlet manifold and warned me of this advance. Mine felt fairly mobile but I couldn't for the life of me get the electrical connections out of two of them, despite removing the U-shaped wire clip. I therefore left them attached and simply lifted the inlet manifold out of the way, resting it on the brake servo - like this:
- In order to get the rearmost inlet manifold bolt off you need to take the fuel rail off OR remove the Fuel Pressure Regulator from the end of the fuel rail. This is a fiddly job although not difficult.
- There is an elusive 11th head stud which isn't mentioned in the manuals. This is at the front of the head on the right hand side and seems to be placed there to help seal one of the waterways. You can see it easily with the engine built up but you can't access it at all well with the inlet manifold in place. Even with the inlet manifold removed it is a nuisance to get to the nut on it as there is too little clearance around it to get a tool over it - none of the 13mm ring spanners we had between us would go over it. We eventually gripped it with a mole wrench to loosen it and replaced it with a new nut, done up as best we could with an open-ended spanner.
- You need to take the cams out of the old head to get to the nuts on the head studs. This isn't hard but you need a good-quality 10mm triple-head tool to get the bolt out of the end of the camshaft. The various guides will talk you through the procedure.
- I turned the engine to TDC on Cyl#1 and marked the cam-belt-to-cam-pulley position with some tipp-ex before dismantling the engine and then replaced the belt and pulley in the same position when re-building it. However I checked the engine timing before starting it up and found out that I was out by one notch on the cam belt. I don't know how this happened but presume we slipped the belt on the crankshaft pulley without realising it. Thankfully I spotted the error and we corrected it before any harm was done.
- We turned the engine over for 10-15 seconds or so with the king lead disconnected once it was built-up to get some oil around the head. Once the king lead was connected it fired immediately and ran very well - it was smooth and had an excellent idle. However the tappets were VERY noisy indeed - noisy to the point that conversation next to the car was impossible with it idling. We left it to idle for 15-20 minutes or so and they improved only fractionally. I took advice from a few people on this, including Tom who had fitted his new head to his S2 a couple of weeks before, and it appears this this is normal. I drove my car to the local petrol station to put some juice in it and almost all of the tappets very suddenly became silent about 1/2 mile into the journey. There was still one ticky one, but this has silenced itself on a subsequent 70-80 mile journey.
- It's worth checking the oil level after you've started the car with the new head as you lose a good few hundred millilitres in the old head when you remove it.
For reference, here are some shots of the old head gasket. I can see what people say when they talk about it not sealing the waterways well after a time but I don't think it's as bad as people make it out to be. Sorry for the poor pictures but this is from an engine with 195,000 miles on it.
Bigger view:
Detail of Cyl#4 (the one that commonly suffers)
Although I didn't compare with the new head gasket I assume that the four holes on the left hand side around the cylinder are meant to be there and you can see that the one to the top right of the cylinder is getting a little porous. However it is still largely in place and I can't think that it would bleed much water from top to bottom.
When I looked at the tops of the cylinder bores I could detect no measurable wear on them - there was no step that I could feel with my fingertips nor could I see anything when I put a straight edge against it. The bores were all perfect, with no scuffing or scoring - which I was both impressed by and pleased with.
Since the work has been done the car is slightly smoother and quieter to drive. I'm not sure whether it has any more pep or not as I've yet to drive it hard with the new head. It may run slightly cooler than before but I'm not convinced, and it may have slightly better oil pressure than before but I'm not entirely convinced by that either. It ran perfectly well before and the work done was mainly preventative maintenance, so I'm not expecting any great improvements from it.
If anyone is planning to tackle this job and wants more advice then do PM me. I know that Tom S (tommys86) and Rob (robdimond) may be planning head-off work on their S2's in the near future so hopefully this will be helpful for them.
Thanks for the write up and pics - its confidence inspiring - especially as you include the tip to avoid having to use dial indicators to re-time the cams. About the 11th stud - is it the one below and slightly behind the water neck in your first picture? Looks like a thin wall box-end socket or maybe a crowfoot would be the tool for this so you could use a torque wrench on it for assembly if your wrist isn't properly calibrated [:)] I've never been afraid to grind down the outside of a wrench to gain clearance - the worst you can do is break your wrench which gives you leave to buy a better one - a win/win.
Bruce,
I don't think I mentioned re-timing the cams as it's covered in the Clarks Garage procedure but thanks for pointing it out. Using three M5 bolts to lock the cam pulley position saves quite a lot of hassle, although I am tempted to check the cam timing on mine sometime to make sure it's right. It would be a shame not to have the engine running to it's full potential.
Yes, you've identified the 11th stud correctly. You can also see it in the second picture, in the top right hand corner just by the blue plug for the water temperature sensor. Grinding a ring spanner would have been an option (and a crowfoot a better option) but we got through without it being necessary.
You've mentioned torques. The guides aren't terribly helpful about this but we did everything up to 20NM unless it said otherwise, which was just about never. There was a bit of debate between me and my friend about the tightening for the head studs - the instructions said "20NM, then 60 degrees and 90 degrees". The debate was whether the 60 degrees and 90 degrees were cumulative or sequential, and we decided it was sequential. In practice this means 140 degrees of turn, which at a thread pitch of around 1.5mm means two thirds of a millimetre of stretch on the head bolts. (Interestingly, the same instruction for the heads on the 32valve 928 - which must be nearly identical - give the sequence as 60 degrees then 90 degrees then another 90 degrees, equating to a head bolt stretch of 1mm.)
Thanks for the clarification - perhaps I'll get up the courage to check my head gasket. Only about 65k miles but as previously pointed out on this forum - its the years rather than the miles that seem to eat these up.
Great job Oli
"thoroughly ruined" :rolleyes: It was at 235k you know!
My new engine is considerably stronger - maybe you'll notice more difference when you manage to get it out of London and onto some proper roads.
235k eh? And all of them done ever so gently .... [:)]
I suspect it will have gathered a few lost horses back into the stable; it felt stronger on the drive home, although I didn't drive it hard. It was certainly smoother than with the old head - which was a pleasant surprise.
I'll see what it's like when it's got a few more miles underneath it and I've given it some beans. Thanks for the encouraging comments!
I could do with the courage plus someone looking over my shoulder whilst doing mine, I don't want to continue fitting the LR turbo without doing it.
Diver944 said:
Lindsey Racing- do keep up Oli :ROFLMAO:
Many apologies m'lud. >Grovel< >Grovel< >Scrape< >Scrape<
Won't happen again, Sir. I promise. >GrovelABitMore<
Yours very apologetically, etc.
Bob,
I wouldn't print them - keep them as digital files and print off the sections only when you need to do so. There is a LOT in there that you will never look at.
Great write up Oli and yeah I'm still talking about tackling mine - so much so I've bought headgasket, oil, coolant, filters, belts, chains etc.... everything plus a water pump which seemed to be going cheap - ECP 25% off aftermarket pump worked out at £73.49 from £97.99 - having gone through all my history which seems pretty extensive, I had no evidence of water pump change.
Reason I'm doing mine though is for piece of mind, I've had it a year now and came across a problem when my distributor packed up about 6 months ago - the dreaded coolant mayo! After quick compression check, seeing approx 180 psi +/- a few (very consistent) across the board I went after the oil cooler seals - cheapest job first.... thought I struck gold when i found an incorrect o-ring and original o-ring (blockside) on either side of the block to cooler pipe (short piece thru the coolant jacket).
Ran the car, flushed it, seemed better, then realised the header tank might be contaminating it and needed a good clean out, another flush.... seemed ok but never perfectly clear - still get a bit of moisture on the underside of the filler cap and steam out the back for the first 10mins.... stinks of headgasket but I have good compression? My final check is going to be get it hot and (carefully) conduct a compression check but I've always wondered is there a coolant and oil channel close to each other that might cause this but show good compression? I've stole your pic to show...so around the cylinder is coolant but what are the other ports below?
Worse case I take it off and everything is fine..... but hey piece of mind, new belts etc are fitted.
I haven't bought new studs and nuts yet because they're bloody expensive! Did you replace or re-use?
Also my head has been done 4 years ago - which made me think it should be ok - but did you skim yours? How many skims can you do?
Ta
Tom
Tom,
From what you say then an oil-to-water leak somewhere from a head gasket that's letting by is a strong possibility. The gasket itself is thicker around the bores (the silver rings in the photo) so I guess it could let by fairly easily although I ain't an expert. I can't off the top of my head remember what the two bottom galleries on that picture do but I think that the square one is water supply and the round one is oil supply, although I could be wrong.
I re-used the studs and nuts on the advice of the people who did the head (Ivor Searle).
I'm not sure whether my head was skimmed; the invoice lists "Face cylinder head" which sounds like it could be but there is no more detail than that. I don't know how many skims you can do either, although wouldn't have thought that you'd have trouble with two unless they were very aggressive and took a lot off.
P.S. If you are planning to tackle that water pump yourself then go gently on the studs holding it on as they can be a pain to shift. That's a good price for one though. If you are doing the pump, belts, tensioners and head then you're in for a good chunk of work - best of luck with it.
Thanks Oli I just read my comments over as I was in a rush on lunch and clearly lost a piece of my mind... peace of mind! Haha yeah the water pump was an after thought - seen a few in the 100s so snapped it up. Thinking of waiting till after Spa for this work as some of these items might be handy if it all goes wrong on day 1!
Pssssttt - nothing's going to go wrong at Spa! You managed a whole weekend there last year without breaking a thing (which I was most disappointed by [:)] ) and I expect this year'll be a repeat of that!
Anyway, you can always plunder my car for spares if you really need them!
Well technically we did have an exhaust failure in race 2 but that wasn't down to poor preparation just enthusiastic driving (not by me either!)
Great work Oli! I'm sure I will get round to doing mine at some point. Bores look perfect and hardly any carbon on the pistons... did you clean them?
