944psi
What should I check if the rpm hunts around when idling? With a warm engine, it returns to idle speed. If the accelerator is blipped say to 2k rpm it then returns to about 4-500 rpm and then to 1200rpm and continues until the accelerator is pressed again.
Is there an idle stabliser that can be checked or is it likely to be something else in the air/fuel system? I read in the manual that any problems with idling could be diagnosed with the plug-in diagnostic box. Would an independant have one of these or would it be an OPC job?
Phil
89 944 S2 Guards Red, black leather, black (rusty) sills, owner still smiling tho.
Phil
