S2 injector removal ?
eddieedmo
I have a spare inlet manifold with injectors still in place ,do they just pull out? I want to have them tested cleaned and refurbed to replace my original ones which have done 180k miles with no attention at all.
Nick
Yes, they just pull out Nick, they have an O Ring fitted where the injectoe goes into the head, so a 90 degree twist either way will help removal, you can get service kits on e bay for around a tenner, look for Bosch Injector Service Kit (or similar)
ORIGINAL: Frenchy
thanks Frenchy wanted to check do avoid damage.
Nick
You need to remove the clip at the top with a pair of pliers or ping it off with a screwdriver first though!
Let me know how the refurbishment of the injectors goes - are you going to put them in an ultrasonic bath or just change the seals?
It's a job I've been thinking about doing for a while and if it's easy and makes a good difference then I'll follow your lead. My S2 has done 180,000 miles as well, hence my interest.
