georgethackray
My S2 Cab has suddenly developed a new feature. If I drive it for about ½hour to get it warmed up, slow down for traffic lights etc., then accelerate, it starts to 'Kangaroo Hop' just like a learner driver[
]. This gets gradually worse but strangely, if I stop the engine (or it stalls!), then restart the engine, the fault disappears completely for a few minutes, then starts again.
I've had suggestions that it could be DME Relay, Flywheel Sender, Hall Sender, Oxygen Sensor or even a decoke needed. The car has been running beautifully for months now. I took it to Bristol 3 weeks ago (220 miles) - never missed a beat. The first indication of a problem was soming back from Bristol where for about 5 seconds it lost power and felt as though it was going to cut out. It picked up again then ran perfectly all day. Most of that day I'd been driving slowly through the snowstorm, but when the fault occurred it was clear.
A couple of days later it happened badly - driving along Blackpool seafront - sunny day, top down, when the power went and it started kangaroo hopping. It dropped to 20 in second gear, and I applied more accellerator. It finally lurched forward to 40 mph ( just missing a speed camera!), and then ran like a pig after that. I had to keep stopping the engine to clear the fault.
I normally use supermarket fuel without problems, but it currently has a mixture of Tesco 99 octane and Shell Optimax in - about 50/50. My first thought was fuel, but that doesn't seem to explain the problem clearing when the engine is switched off for a few seconds.
So, after that essay - any ideas anyone?
